Different Ways to Backup FTView Programs
zacslade
Oct 2014
Phoenix, AZ
84
Hi All,
At this time, I'm aware of at least three ways to backup a project in FactoryTalk View. Each way produces a different type of file. Honestly, I'm a little confused about why they would make so many utilities that do essentially the same thing in different ways.
These are the methods I'm aware of:
Rockwell Software/FactoryTalk View/Tools/Application Manager
- Does not work for Network Distributed projects
- Produces *.apa file
Rockwell Software/FactoryTalk View/Tools/HMI Server Backup and Restore
- Produces a copy of the files in the project directory(?)
Rockwell Software/FactoryTalk View/Tools/Distributed Application Manager
- Only works for Network Distributed projects
- Produces a *.apb file
Rockwell Software/FactoryTalk Administration Console
- Only works for SE projects(?)
- Produces *.bak file
What are the advantages/disadvantages of each tool (for example, what's the difference between a .bak and a .apa for a local station app)? Did I miss any in my list?
The Application Manager should be used for any ME application as well as Local SE applications. Use this to backup and restore applications between different computers or the same computer.
The *new* Distributed Application Manager should be used for Distributed SE Applications. This tool is new in either v8.0 or v8.1. I don't recall exactly which one added this tool. This tool allows you to backup and restore all components from a distributed application to one single file. Previous to this tool, several tools were required.
Those are generally the two you really need.
But.....the HMI Server Backup and Restore tool could still be useful if I just needed to backup one specific HMI Server in a large distributed application. Previously for a Distributed Application each HMI server had to be backed up separately. Five HMI Servers required five different backups. The new tool captures the entire application in one file.
The FactoryTalk Administration Console backup would still be a useful tool to backup only the contents of a FactoryTalk Directory (Local and Remote). If I just want to capture all the user accounts and back them up along with any policies then this tool can do that for me.
OG
Hi all. New here and wondering if you can help. I have a flasher unit I want to test via PLC. The issue I am having is the input signal is 12v+...
203
114
What happens if you power up a 1783-MS10T with a Compact Flash card from a 1783-MS06T? Does it work, but with the "extra" ports unconfigured? If...
74
Hi, I want to build a demo station to test devices and programs and I need some help with it. I want to connect GuardLogix, Piltzmulti and...
149
Hello guys, I am new to this forum and have some problems with my PowerFlex755 EENET frequency inverter. I want to do a point to point...
387
