ADD [Addition]
Rockwell Software
When rung conditions are true, this output instruction adds Source A to Source B and stores the result at the destination address. Source A and Source B can either be values or addresses that contain values, however Source A and Source B cannot both be constants.
If you are using a 5/02, 5/03, 5/04, 5/05 or MicroLogix processor, you can use indexed addresses for the source or destination parameters. If you are using a 5/03 OS302, a 5/04 OS401, or a 5/05 processor, you can use indirect addresses for the source or destination parameters.
32-Bit Addition
If you are using a Series C or later 5/02, or a 5/03, 5/04, 5/05 or MicroLogix processor (capable of 32-bit addition and subtraction), you can set the math overflow bit (S:2/14) in the status file. This causes the unsigned, truncated, least significant 16 bits to remain in the destination.
If this bit is not set and an underflow or overflow conditions occurs, the operation will be the same as with a Series B 5/02 processor. The destination address will contain a 32767 (if the result is positive) or -32768 (if the result is negative).
