Digital input/ analog output
rheilman
Apr 2004
Hardware Configuration for Versamax
MAIN RACK
PWR IC200PWR101
SLOT 0 IC200CPUE05
SLOT 1 IC200MDD845
RACK 1
PWR IC200PWR101
SLOT 0 IC200ERM002
SLOT 1 IC200MDD845
SLOT 2 IC200ALG320
Programming with CIMPLICITY Machine Edition with PLC LD Instructions
I am looking for ideas to develop logic to control the level of a product in a bin by controlling the speed of a feed belt that is four minutes and several large pieces of equipment upstream from the bin. There are four on/off level inputs: a low level, middle level, high level, and an overflow level. The output will need to be in an analog 1-10 VDC signal that will control the feed conveyor motor speed. Bottom line is using digial inputs and timers to develop a scaled analog output. Examples would be very helpful. Thanks Rheilman
I do this all the time...
This can be likened to doing a weighing operation with multiple setpoints.
Let's assume Speed=Output Speed, 10V=Fast, 7.5V=Medium, 2.5V=Slow, 0V=Stop, and the Analog Output card is scaled for 0=0V and 4095=10V:
If HighLevelSensor=High then Speed=Stop
If MedLevelSensor=High then Speed=Slow
If LowLevelSensor=High then Speed=Med
If LowLevelSensor=Low then Speed=Fast
If OverFlowSensor=High then Turn On Alarm
All this assumes that the sensors are not in the product stream.
This works well for straight ladder logic. I use AutomationDirect PLCs and use Block/Stage Programming so my ladder logic looks a little different.
I am not familiar with the CIMPLICITY line so maybe someone else can fill in the blanks.
You would also need to build in alarms but this is the basics.
Hello, I have a small programming task that I need help solving. I have to: * Create an analog input (4-20v)and a digital output * The analog...
45
25,198
Hello everybody. for an asignment we are using a s7 1200 siemens starterkit to connect sensores to create a program. we were hoping to save some...
6,531
On a Micrologix 1100 analog input, I appear to be getting an internal offset of about 11 counts out of 1023. Running the program from RSLogix...
4,418
Hi, hope this is not too boring of a question but wondering can a analog input on a micrologix 1400 be used as a digital input? thank you in...
2,470
Within a Chemical/Process Plant what type of instrumentation is considered Digital Input, Digital Output, Analog Input or Analog Output? Where...
3,890
