Disconnect BOU Honeywell DCS TotalPlant Alcont
Kataeb
Jan 2007
www.livelovelebanon.com
636
Hy, we have a Honeywell DCS TotalPlant Alcont, to which we added a new digital output module BOU. On this module there is a Disconnect or D switch which sets all the channels on the card into a passive state. We put this switch to Connect position, but no outputs are enabled.
Has anyone seen this before? How can we solve this problem?
In the Honeywell manuals it is mentioned: For card replacement the outputs are reliably switched off by turning the front panel DISCONNECT lever to the right. This must be done both to the old and the new card. The lever must not be operated during normal operation, because an erroneous control would be caused by clearing all the output channels.
Thank you
333
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
366
Good afternoon PLCS.net! I have a very odd situation that is happening, and hoping someone has some insight. We have just laid out a new 10G...
668
This question is about a Q68TD-G-H01. When I disconnect the thermocouple connected to channel 8 of the module, I am expecting D111.F to go TRUE...
3,490
For those of you that design / build panels: Do you typically provide a fuse / circuit breaker on your main disconnect inside the panel? We...
5,138
