For those of you that design / build panels:
Do you typically provide a fuse / circuit breaker on your main disconnect inside the panel?
We always have, but I've seen some panels we purchased from other vendors and not one of them has a main fuse. The motors / transformers are all protected, but there is only a disconnect on the main - no protection.
Looking through the code, it appears it is not required. Is this typically something the customer / building would state? I would assume it is better to have than not - but it is also more expensive.
Thoughts?
Thoughts?
