Disconnect or FUSE ???
Orn Jonsson
Apr 2002
Boise Idaho
125
When installing a new machine on the factory floor, what determines whether the machine should have a disconnect or a fused hookup.
Someone told me that if you could not see the feeding panel from the equipment that you should install a disconnect???
Any standards on this one.....
European way: With every motor have own 'Safety Switch' for main voltage disconnection very near the Motor. SW inludes aux contact for feedback information 'Safety Switch ok.' to PLC or DCS.
SW can locked by 4-5 padlocks. Everybody puts own Name Label whos paflock is it.
Usually we don't use fuses but Motor Circuit brakers with adjustable OL-protection and aux contact for PLC. Contactor Feedback tells also something is wrong, but not when there is not 'Run command'.
I hope understood you question.
Yes there are codes involved
Simple solution, use fused disconect.
When I have partaken of less malt I will attempt to specify the codes.
For those of you that design / build panels: Do you typically provide a fuse / circuit breaker on your main disconnect inside the panel? We...
5,094
326
Here's what happened, Operator turned on the disconnect for an auger while it was still running to cut power. Auger DID in fact turn off, but the...
359
Good afternoon PLCS.net! I have a very odd situation that is happening, and hoping someone has some insight. We have just laid out a new 10G...
667
This question is about a Q68TD-G-H01. When I disconnect the thermocouple connected to channel 8 of the module, I am expecting D111.F to go TRUE...
3,488
