dislpay "plc has fault"
boubb
Guest
B
hi
Happy new year to all,
The PLC is GE Fanuc 9030( logic master )
the control panel is from Total control.
1_ How to display when a (PLC or I/O) has fault in HMI
(using quick designer )?
2_ can we display the number of faults also ?
thanks
excuse me for my english
There are several system bits (%S) that indicate fault conditions. Your HMI can monitor them. For example, %SC0009 is set whenever there is a fault, %SC0010 is set when the fault is in the PLC fault table, and %SC0011 is set when the fault is in the I/O fault table.
In ladder logic, you can include a Service Request #15 to read the most recent fault table entry. That will fill an array of data registers with fault data which can be displayed on the HMI.
Is there a way to display jpg files in displays in Rsview. What I what to do is call them up from a touch animation? Thanks for any suggestions.
1,570
kindly need to understand why can't upload the plc
35
Hello all, I have a one problem. I would like to upgrade Mitsubishi PLC Q02 to Q03UDVCPU. I have Q02 program and I change to PLC type and try to...
28
241
the conveyor can stop because of a safety sensor or safety switch. And also it can stop because of an object jam detector sensor. If the conveyor...
195
