Display Error Codes from K550 CIP Drive to HMI
Daffi
Mar 2013
Ireland
Hi Guys,
Has anyone ever displayed error codes from a cip drive to a HMI?
I contacted Rockwell and they gave me a sample bit of code but it will only open on V28. The manuals surprisingly, are a bit vague. Getting up axis status seems to be straight forward enough as long as you know the corresponding Hex/Decimal values.
Any help would be appreciated.
Daffi
I have. Attached is a screenshot for something I did with AdvancedHMI and a PF525. You can download faceplates from Rockwell, this link should work for kinetix:
http://search.rockwellautomation.co...D:L:d1&wc=200&wc_mc=1&ud=1&filter=0&q=kinetix
I don't like their stuff, so all I use is the multistate data. If using ME/SE, you can use excel to easily edit the states in a multistate. I used an INI file for AdvancedHMI, I attached that as well, except as txt.
So, all you do is look at the fault code value from the drive via the PLC and then lookup the text to display on the HMI... very simple.
James
  • PF525_Fault.txt
Hello, I am learning to create shapes and VB Scripts in HMIWeb Display Builder. I wanted to change color of my rounded rectangle by script. I...
113
ohh boy im in a bind. currently on a shutdown right now and im burning the midnight oil because i cant get the customer's used PVP1500 to...
2,607
Morning. Have a 2 Sercos Ultra 3000 drives configured onto RSL5k Version 20. I want to display that text message for the drive and axis status...
1,276
Hello everyone, I'm having trouble with a message display on a PV 550 (Cat 2711-T5A2L1, Ser B) and Micrologix 1500 (Bul 1764, LSP Ser C) I am...
1,566
Hey everyone, Currently I'm using FactoryTalk View Studio to work with PanelView Plus Compact600. Basically, I need to display a simple message...
1,688
