Display from event with RSView SE Distributed
Greg Fowlds
Apr 2004
Currently, Waiheke Island, NZ
123
Any one know how to popup a display from a Macro, Event or VBA on PLC bit change.
I am trying to pop a window when a bit is set in PLC.
Can trigger an event OK from PLC, but if in event action is "Display mywindow"
i get the message, "cannot open display from HMI server, must be from HMI client"
Same if I try from a macro that runs from event.
Works fine if same popup is triggered from an event from an on screen button.
I am wanting to put some data into a CSV file on a PLC Bit change.
For VBA to work it must be attached to a display and only appears to get tag data from that window and not direct from PLC.
So will need a window to open to trigger the VBA to do the save.
Without operator control.
Anone have any thoughts.
If that hidden window does not have focus would the VBA still be active and be able to pickup a tag change?
This is the version 4.0 SE.
I see that in 4.0 the VBA is only attached to the page.
Cannot find any client wide code area?
Hi all, I have a network distributed FTView SE system, which has three clients, showing alarms for three different sections of plant. I have...
4,457
I'm trying to make a display open triggered by an Event, but I keep getting: "The command 'Display' is ignored when issued from the development...
39
13,942
In a standard VBA form you can have a Form_Timer event that executes periodically. Is it possible to configure the same thing in SE? We want to...
1,539
If an RSView32 works project (version 7.5) consists of several screens, named for example: Screen1 Screen2 Screen3 . . . . Screen-N What is...
1,480
Hi All Using RSView SE. How can i popup a display on event such as NumericInput_Change() (command display is ignored when issued from HMI...
3,482
