Possible to program a Timed Event in a FT SE Display
sanger
Nov 2005
Toronto
172
In a standard VBA form you can have a Form_Timer event that executes periodically. Is it possible to configure the same thing in SE? We want to create a form with VB code that interfaces to an external communication module in a DLL and need to poll the DLL periodically for processing messages.
Found my own answer.
- On the display create a NumericDisplay control named say "Update" and assign it the tag {system\Second}
- On the properties panel for the NumericDisplay set Expose To VBA to "VBA Control"
- Right-click on the control and select VBA Code. This will create a subroutine named Update_Change() that will be called once per second.
I will be designing an automated hydrostatic system. The system on paper works like this, a plc like the click will get information from an hmi...
227
43,321
Hello. I have been trying to crack this one without success and could not find any hint after several search attempts. I wonder if any CODESYS...
3,948
Hello, I'm pretty sure I know the answer to this, but wanted to verify with the experts. Am I able to write a program using the Micro Starter...
3,172
First off, i am new to ladder logic. I do have some experience programming microcontrollers in C. I will try and give a short version and if more...
2,033
This is a CompactLogix L33ERM, version 30 (31 is too unstable on my machine to work with), with a Kinetix 5500 drive. I have a program where...
2,025
