Possible to transfer a program to RSLogix 5000
Apr 2020
USA
50
Hello,
I'm pretty sure I know the answer to this, but wanted to verify with the experts.
Am I able to write a program using the Micro Starter Lite free software, and then transfer it to RSLogix 5000? We only have one seat of the RSLogix 5000, and I was hoping to program a ML 1200 and then transfer it when ready. Thank you.
A couple of key points for your question.
Micro Starter light can only be used to program the MicroLogix 1000 and 1100, not the 1200.
RSLogix 5000 does not program any of the MicroLogix family of controllers. Did you mean to say RSLogix 500? In either case the Micro Starter will not work for the initial question of programming the MicroLogix 1200.
Hope this helps you out.
If you program the ML and post the zipped program here I am sure someone could open it, change the CPU type to SLC5/05, verify and post it for you - hopefully mentioning any verify errors that popped up.
Then you could use the free convert utility from Rockwell to change the 5/05 program to Studio5K
Thanks for the feedback. I did mean to say RSLogix 500. This helps.
Thanks! Seems like the better thing is to either purchase a ML1100 and program with the free software I have, or purchase another seat of RSlogix500 software.
If I was going to purchase the RSLogix Micro Developer or Starter edition software, are those only available through a dealer? I could not find an option to purchase on Rockwell website.
you'll need to buy it from an Allen-Bradley/Rockwell distributor ...
but ...
if you're going to a school (you didn't say) you might be able to get a deal ... sometimes they'll be able to set you up with a cheaper price - or maybe even a free "time limited" license ...
good luck with it ... and welcome to the forum ...
which keys should we press to make the op77a switch to transfer mode? it is only displaying " This device contains free software ... "
1,663
I have a original programs with comments of the ab plc 5/04, when connect my computer I pulled a program copy without of comments, is possible...
1,949
Another one for Simon! This is related to the BLOCK_DB question in as much as it's the same program. I need to pass over the Cell address in the...
3,898
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
221
Hello The plant is running and there is no shutdown nowadays therefore I can add 1734- AENTR and its card while PLC is in Run? I do not wanna...
352
