chavak
- Join Date
- Jul 2002
- Posts
- 751
Hi guys,
How do I display ST file data on PanelView 600 reading from SLC5/04.
The tag 'Data-1' is created as ST19:1 - Character Array
The only option I found is to add a text + Embedded Variable [Character], but PV doesn't displays any data keyed in the ST file.
Maybe What I'm doing is totally wrong -
Actually I am reading 5 inspections values thru a Prosoft MVI46 module to an ASCII File A20:0.
Then I copy the actual inspected values minus the alpha characters, say for Eg:2.456 to ST19:1 thru ST19:5. The data is appearing well in the ST File. But never display out on PanelView.
Pls help
Thank You
_________________
Pls help
Thank You
_________________
