Displaying HEX number on PanelView
TheStarr
Jan 2009
Florida
383
Ran into a strange problem. How do you display a Hexadecimal number on a PanleView 600?
The PLC is a CompactLogix.
The value is passed into the PLC from an extrenal source into a "HEX" style tag.
The PanelView does not have the option to display a hex, only an integer or a string.
Is there an easy way to convert the hex to a string?
All of the hex converters I have found change the hex to it's ascii form, this is not what I want.
I need to display the hex digits.
Example: 2D3FF43A hex in PLC; display on screen as "2D3FF43A"
I don't know of any way in a PanelView or PanelView Plus to display a value in hexadecimal.
In a dozen years working with both platforms I have had to do this only twice. I used Masked Move and Divide instructions to get each digit of the hex value into its own register, then displayed the value digit-by-digit with a multi-state indicator.
Crude and troublesome, but it worked.
Are you using a PanelView Standard 600 or a PanelView Plus 600 ?
That is what I was afraid of.
We have already got a basic "divide and conquer" setup going, but it is very labor (rung) intensive.
UPDATE!!!!!
After many attempts with AB Tech Support, they finally came through with a slick fix.
They have created an "Add-on instruction" called "Hex2String"
The processor must be upgraded to version 16, then you right click "Add-on Instruction" and "Import" the attached L5X file.
Works great!
P.S. We tried it on a PanelView Plus 400 and it worked perfect.
Thanks for the input.
Hi Everyone, Just wondering if anyone could help me with an issue I'm having? I'd like to display a fault code that is referenced in Hex on an...
1,587
Does anyone know how to keep Hex numbers displayed in VersaPro? I enter in the Hex numbers, then when I reopen the folder, the numbers are...
4,723
Hey everyone and anyone that can lend a helping hand. I have a project that I am being asked to add some animations of Solidworks or "3D" models...
342
Using FTview ME to create an HMI screen. Simplest task is giving me trouble. How do I create an HMI tag that will allow the name of the current...
133
Hello Folks, plc : micrologix 1500 The analog output from the loadcell is given to the plc. Using the SCP function I have scaled it into an...
764
