Displaying Hex values in iFix
Marshy
Apr 2007
Bath,UK
236
Hi Everyone,
Just wondering if anyone could help me with an issue I'm having? I'd like to display a fault code that is referenced in Hex on an iFix screen.
The IFix version is 5.8 and I'm using an IGS driver connected to an S7-1500 PLC. The AI datablock has no signal conditioing. I've tried referencing tag with node.Tagname.A_CV & node.Tagname.F_CV with Raw Formatting enabled with %x and %X. None of this has worked.
Does anyone know if it is possible and if so how do you do it?
Thanks in advance!
Rich
Got it working with a script in the end. A bit messy but it works
Code:
Dim intValue As Integer
Dim intIndex As Integer
Dim strHexValue As String
Dim strPicname As String
Dim txtBoxRead As Object
Dim txtBoxWrite As Object
strPicname = Me.Name
'intIndex = CInt(ReadValue("Fix32.PURFLEET.LMV5_FAULT_Index.F_CV", 2))
For intIndex = 0 To 3
    Set txtBoxRead = System.FindObject(strPicname & ".txtDetail" & intIndex)
    intValue = CInt(txtBoxRead.Caption)
    strHexValue = Hex(intValue)
    Set txtBoxWrite = System.FindObject(strPicname & ".txtErrorDetail_1" & intIndex)
    txtBoxWrite.Caption = strHexValue
Next
Exit Sub
Ran into a strange problem. How do you display a Hexadecimal number on a PanleView 600? The PLC is a CompactLogix. The value is passed into...
7,549
Does anyone know how to keep Hex numbers displayed in VersaPro? I enter in the Hex numbers, then when I reopen the folder, the numbers are...
4,723
Hey everyone and anyone that can lend a helping hand. I have a project that I am being asked to add some animations of Solidworks or "3D" models...
346
Using FTview ME to create an HMI screen. Simplest task is giving me trouble. How do I create an HMI tag that will allow the name of the current...
134
Hello Folks, plc : micrologix 1500 The analog output from the loadcell is given to the plc. Using the SCP function I have scaled it into an...
765
