Dissecting an EDS file for non-RSNetworx
Scott180zip
Oct 2008
Brunswick, OH
16
Here is a challenge:
I am using a i-7243D Gateway (DeviceNet to Modbus/TCP/IP) to pull in DeviceNet data from a VFD (Alvitar 71 - Schneider Electric). I only need limited information from the Drive (i.e. RUN/STOP/POWER/FAULT). The client wanted to save money and did not want to use an AllenBradley DeviceNet scanner. The Alvitar 71 instructions use RSNetWorx to pull in the device data. Unfortunately RSNetWorx does not read Modbus so I must import the data by setting up an ARRAY in the Gateway's ICP-DAS Configuration software. Has anyone had any experience in this procedure? I attached a bitmap showing an example EDS text file and the device configuration screen for the I-7243D Setup.
Any help would be much appreciated.
My preferred Modbus/TCP to DeviceNet bridge is the AnyBus-X version from HMS Fieldbus. It can use the familiar RSNetworx for DeviceNet software to configure its scanlist.
Post a link to the Altivar 71 EDS file, and preferably also a User Manual for the DeviceNet interface.
Post a smaller screenshot of the ICP-DAS utility configuration window for a connection to a DeviceNet slave. You should be looking for a place to enter I/O Assembly instance numbers and sizes.
Here is a challenge: I am using a i-7243D Gateway (DeviceNet to Modbus/TCP/IP) to pull in DeviceNet data from a VFD (Alvitar 71 - Schneider...
1,959
Hi, I'm trying to import a Rockwell/AB EDS to Beckhoff but I'm not sure how to import/install the EDS. It is a PowerFlex 525 EDS. Is there a way...
64
Hey y'all!! I'm looking for an old EDS file, GSE 560. I can't find them anywhere. It is for a GSE560 display on a DeviceNet network, with...
103
Hello, This product that I have the 1790D-T8BV8B is discontinued, does anyone have the EDS file for it? I wonder if TechConnect will have this...
200
Im trying to teach a couple of labs on VFDs at a community college. We have some motor control trainers with P525s and 3 phase motors from...
267
