Dl240 with analog 4-20 input
Thanks guys, I have it working! Had to connect my loop simulator - to + and + to -, and it runs a very accurate 0 to 4095 (100%).
Thanks so much!
Your data will arrive in V2000, V2001, V2002, V2003.
LDA O2000, OUT V7673 (V7673 is the module's pointer to the data location (V2000)).
It looks kinda cryptic because it is. This is definitely NOT the only device that uses cryptic configuration / programming style.
I play with this not because I have to, but because I want to learn it. RSLogix is so much easier, and way more expensive! I'll get used to this eventually... maybe!
I've got it displaying (thru the DATA icon) values and am using a loop simulator to input 4-20 ma. Works great and accurate!
Thanks so much for helping me get this going!
Hello PLCs. I need assistant with my current problems with the H2-ECOM100. Machine configuration: DL205 with DL240 cpu, and H2-ECOM100 plugged...
3,679
Hello, Wondering if anyone could possibly shed some light on an issue with a Direct Logic 205/DL 240 CPU. I'm having zero luck talking to this...
2,784
Original system has one pump and 26 hoppers. Each hopper has a Full switch. Only one input was used on the PLC for the Full switch. Operator...
2,450
So I've got this project where I need a LOT of adjustable timers (each with different times). So I was thinking of using the 4 Pots on the DL240...
3,531
Attached is a Directsoft file for a machine that watches the next machine upline for a ready signal, and if the signal (X11) is there it sends...
30
7,647
