Do-More and EtherNet/IP
XtremeIN
Jun 2005
Indiana
217
Hello all,
I am working on a project the requires a Do-More H2-DM1E and an IFM AL1020 (https://www.ifm.com/mounting/7391037UK.pdf) to communicate via ethernet/ip. I have browsed several manuals, watched videos, and searched the web and this forum. I am at a loss. If my understanding is correct I need to use the EIPMSG command and that the Path fields need to match the IO block in order for communication to occur. I do not understand how to read and use the charts for the Class, Instance, and Attribute. any sort of help would be greatly appreciated.
Thanks,
Micheal
Thanks Gary!
I had some time this morning to do some testing. I got the comma working and I can request and receive data. If I use class 1, instance 1, and attribute 1, I get 322 which is the vendor ID, which is correct. But I can not figure out what values to use to get a digital reading from a pressure transducer on port 1.............
After about an hour of testing I was unable to get anything other than some basic data from the IO block. A quick call to IFM and they confirm are that the Do-More series of processors is not comparable with the IO block. Their recommendation for a budget setup was the Automation Direct P2K or the P3K and a different IO block (I don’t have my notes, I think it was the AY1122).
Automation Direct also has a P1K (Productivity 1000 Series) that uses the same software as the P2K and P3K.
The cost of the P1K is similar to a Click.
Regards,
Have you tried posting this on Host Engineerings forum?
You'll be talking directly with the designers and engineers that created the Do-More.
They are also on the Automation Direct forum regularly too.
The engineer from IFM said they have tested and have documentation on intergtating their IO Link block with the P2K and P3K, he did not mention compatibility with the P1K. I know nothing about the P series. Going with their recommendation.
The project manager has been in contact with someone at Facts and he simply referred us to section 18 of the manual.
Thanks everyone for the suggestions!
Hello, I am attempting to set up Ethernet coms between a L06CPU and a Cmore EA9-T6CL HMI via Ethernet with no success. There is no Ethernet...
1,888
Hi, folks, how’s going? We just get one new production line with Logix5000 system. But I cannot understand why there are 4 Ethernet cards and 1...
17
14,176
A customer has a PLC5/40 that has a 1761-NET-ENI (series C) connected to the DF1 communication port. They have an old Panelview HMI connected on...
4,675
I understand how the system works: EA7 (Cmore) <--RS232--> DL260 (PLC) <--Ethernet--> LookoutDirect 4 but I have no idea if its possible...
1,840
Hello, I'm using a ControlLogix controller with 1756-ENBT to communicate with an I/O adapter using EtherNet/IP. RSLogix 5000 v13.03 is being...
14,551
