Does anyone know what components or modules I need to buy so I can bring this load si
Hi Piscis,
If you look at the spec pdfhttp://www.ricelake.com/docs/prodinfo/lcg_pdf/RiceLake/single_point/RL1380.pdfyou will see that it needs a clean 10 VDC power supply for excitation. Then you will need an anilog input card, F2-04AD-2, which will fit into an empty slot in your AD-260 rack. Most of the 12 VDC supplies that AD sells can be turned down to the needed 10 VDC.
Hope this helps.
David:site:🍻:site:
They are installed in a control panel that was made in France and are intended for the termination of analog inputs. Each of the red capped...
420
Need some help here (again). I tried to download my HMI to the PLC and I get this error message about a missing file. Can anyone help?
813
Hi there, I need to work on a GE series 5 PLC which need DOS based Logic Master 5, it seems like nowhere I can purchase this software anymore...
955
Would like to ask .. if anyone here know about creating own library or function block on ProWORX NxT ? I have a backup of ProWORX NxT project...
1,055
Does anyone have a spare PacDrive part# LMC600CBD10000? Not necessarily for sale, but to do a bench test. I have a CF image file, and I'd like...
1,263
