Does anyone know where can I find a tiny PLC
piscis
May 2003
241
Does anyone know where can I find a tiny PLC with one input and one output? The Tri-PLC is too big for my application. I need to embed this into a small commercial product and the only space I have is 2”x2”. I could use a PLC on a PCboard type.
Thanks all!!!
The Divelbiss PLC-On-A-Chip is the one I was planning on using on the first place but then the space restrictions on this project got tighter. This will be used for monitoring machine usage, a sensor will detect if the unit has not performed a cycles within the last 30 minutes and will shut down the machine.
Tiny PLC
If you'd care to contact me off thread, Divelbiss would be happy to discuss an embeddable control card to meet your needs.
Mike
This application has to be resolved in terms of space restriction not function. If anyone can find a timers or a smart relay or a board plc with this dimensions I will be more than happy, 2”x2” with a thickness of not more than ½ an inch. I could also settled for (2”x5”x1/2”)
The smallest I have is a Keyence 2.25x2.75x1.75 this is a 6 in 4 out not sure but they may have smaller??
Try using a "nil speed switch" module designed to monitor whether a conveyor, elevator or similar machine is running. It usually uses a proximity switch as its input but this can be from some other source.
I use these as a watchdog timer monitoring a pulsing PLC output and alarming in the event of PLC failure.
Hi there, I need to work on a GE series 5 PLC which need DOS based Logic Master 5, it seems like nowhere I can purchase this software anymore...
979
I have been asked where to get pro face Hmi software from, I have been told that it's a free download but I am not sure can anyone help thanks stu
5,181
2,248
They are installed in a control panel that was made in France and are intended for the termination of analog inputs. Each of the red capped...
451
Need some help here (again). I tried to download my HMI to the PLC and I get this error message about a missing file. Can anyone help?
876
