Does anyone use F Ladder from GE?
KA24DE
Oct 2003
21
Hey folks, I am just wondering if anyone uses F Ladder which is an application for programming the Ladder portion of GE/Fanuc PowerMate controllers?
I am having a compatibility problem with this program running on Windows XP and 2000. This was originally a DOS program and I have had no problem running other DOS apps on my machine and i have gotten it to work on one windows 2000 machine but i cannot replicate it on others.
Does anyone have experience with this problem, I believe this is related to the video drivers because the program runs but once you try to activate the menus, it shows garbage on the screen.
Thanks for the help
When you say it shows garbage on the screen, do you mean that it scrolls a bunch of meaningless text with a lot of backwards-pointing arrows and "[" characters and such?
If so, then the program can't find a driver called ansi.sys. You will need to install it or define a path to it.
They are installed in a control panel that was made in France and are intended for the termination of analog inputs. Each of the red capped...
445
Need some help here (again). I tried to download my HMI to the PLC and I get this error message about a missing file. Can anyone help?
863
Hi there, I need to work on a GE series 5 PLC which need DOS based Logic Master 5, it seems like nowhere I can purchase this software anymore...
972
Would like to ask .. if anyone here know about creating own library or function block on ProWORX NxT ? I have a backup of ProWORX NxT project...
1,067
Does anyone have a spare PacDrive part# LMC600CBD10000? Not necessarily for sale, but to do a bench test. I have a CF image file, and I'd like...
1,270
