Does siemens have a flip/flop
Foty
Oct 2002
30
I was wondering if siemens has a Flip/Flop function.
Basically I would like to turn on/off an output with the same input.
For example P.B.1 is pressed and let go, output on. P.B.1 is pressed and let go again, output off. :)
Lots of our equipment uses a N.O. PB to a counter file. Then you use the first binary bit of the counter ACC to activate the output.
I am not good at this but having to troubleshoot code alot I have learned a simple and easy to understand method for a toggle/flip flop circuit. This is using GE symbology but can be used in any ladder including Siemens.
Code:
[size3]
|%I0001                                                  %M0001
|%M0001  %Q0001                                          %Q0001
|%Q0001  %M0001 |
This can be added to make it alternate 2 outputs
|%Q0001                                                  %Q0002
[/size3]
.I cant speak S7-200 because my Micro/Win disk 1 is bad and wont let me reinstall but I do have Simatic S7 and I entered this code in it and even the symbology is similar.
I then let the software convert it to STL
ALL of this is easy to understand and can be used in any plc (I think) but what makes Siemens and this Function Block stuff cool is that you can create things like this
One of these days I am going to learn this stuff, maybe I will get it before I retire.
Need some help here (again). I tried to download my HMI to the PLC and I get this error message about a missing file. Can anyone help?
858
The picture attached relates to the properties for the F9 key. Does anyone know what 'object number' refers to? What does 'object number' mean...
734
I am new to Siemens, and just looking into their HMI software. Does Siemens have a product similar to FactoryTalk View SE? I am looking to have...
1,767
Hello Everyone If a Siemens PLC does not contain the optional battery or if its battery is discharged, will we lose the program if the super cap...
1,029
Hello, I am sending data from a siemens 319-3PN/DP Plc with a Additional Cp343-1 card from the Plc to a remote BNR pc. I have configured 2 tcp...
2,191
