Doing Edits in an AOI Logix5000
showshocka
Mar 2011
USA
510
Hi. How would I do online edits in "one" particular AOI without affecting the Main Definition? I am not sure at all of how accurate this is but I have heard that this can also be down without going offline and re-downloading to the processor after the edits. Thank you all.
What you describe isn't possible per se. An AOI by definition has to be the same for all instances.
If you want to try something different with one of those instances, what you'd do is to duplicate the AOI, call it something like "My_AOI_Modified", and make your changes in there. Then, for the instance you're wanting to change, change the data type of the AOI tag from "My_AOI" to "My_AOI_Modified". Of course, all of this must be done offline and downloaded.
One caveat to ASF's response on duplicating and modifying an AOI. You can create your new modified AOI offline, export it (right mouse click on its definition), and then import it into your running processor. You can then create new instances of the new modified AOI and begin to replace the old AOI. Its a much longer tedious process but if the processor can not be shut down, its about the only way.
If I think for a second I may have to edit re-usable code online, I use a UDT and create a subroutine with a general purpose name, place it in the unscheduled folder and use it as a template for whatever instance I need it for.
And yet, many people swear that AB is the perfect PLC system... honestly, I can't understand how people put up with it.
If there were any "Perfect PLC System", then everyone would use only that no matter the cost. AB PLC's are solid, reliable, and functional, even with Rockwell doing everything they can to kill them off.
It's true that they know their stuff... and their products are solid, but in this day and age this seems to be a huge limitation for their systems.
It's basically an half assed attempt to achieve what Siemens had all along... "here guys... you now can have a function in the true sense of the word." Ohh and by the way, if you need to change it you'll have to stop the PLC to implement anything.
They all have strengths and weaknesses, but this one is a hard one to swallow.
Until "Bubba" does an online edit to an AOI without realizing they are changing every instance causing a spectacular failure of some unrelated device.
If you want that functionality, you use a subroutine and subroutine parameters. Works exactly like a Siemens FC and can be edited online.
I'm a huge fan of AOI's, when used correctly. If you find that you keep on having to do downloads and make changes to your AOI's, you're not using them correctly.
Pretty much all my AOI's are device-based. Over the years I have developed them for DOL motors, VSD motors, weight transmitters, pneumatics and hydraulics, barcode readers, and so on. Once you've got all your features in place, tested and proven, you never need to touch the AOI again. What makes the motor start and stop happens outside the AOI, so that can be changed at any time, but things like auto/manual mode, overload/isolator/starter feedback, and so on, never change.
Sure, every now and then some application or another calls for a new feature that my AOI doesn't have, so I add it to the AOI and up it to v2.0. I've never yet found a feature add that wasn't backward compatible to my previous iterations.
Me personally, I'm not a huge fan of Siemens. Everything just seems way harder than it should be. But I don't for a moment imagine that it's because AB is inherently better than Siemens - it's purely that I'm better at using AB. If I had more practice on Siemens, I'd get used to thinking the way Siemens engineers expect you to think, and I'm sure at the end of the day it'd be just as powerful.
Good Afternoon, I'm trying to do online edits on a SLC 500 5/05 . After I put my instruction in , I keep getting " Test Edits Failed " ...
3,764
I am latching and unlatching "result_Data_latch" bit within same rung. Will This copy/move instruction execute correctly??
202
Hi All, I have a click plc the I need to bit strip and 16Bit int. This is to get the alarms from these bits in the int. Do anyone know how to bit...
517
In Easy Builder Pro: Unexpected results... I've got a toggle switch set to trigger a macro to write a specified integer or a 0 depending on the...
2,322
Good Morning , Since I’m loading a new laptop , what are you doing for the 32 bit FactoryTalk View projects that you run into ? Are you...
3,827
