Door mount breaker w/ weather cover
Snyd1
Jun 2018
there
225
Good evening all,
I have been searching in vain for a single pole breaker that can be mounted to the door of an enclosure. The toggle should be accessible from outside the enclosure and covered by a weather proof and lockable plate/cover.
Any ideas? Have not come across exactly what I have in mind through my searches. Guess if it comes down to it could just get creative and build our own mount for a standard din rail breaker and grab a Hubble cover.
Carling has been around in the toggle switch business forever.
I think Cuttler-Hammer use to make them as well. Who knows what company wound up with that product line. They used to be pretty standard devices used as on/off switches for a lot of commercial/industrial appliances.
What is the purpose of your circuit breaker? Is it a Supplementary protective device or does it need to be the Branch Circuit Protective Device? Most of those little devices like the Carling are Supplementary only so since you will need another BCPD anyway, just use a standard toggle switch and WP cover on the door.
It is for supplementary protection.
I've noticed a strange behavior with certain rotary disconnects. We all know that, if installed correctly, the disconnect interlocks with the door...
1,469
I have noticed that many HMI have a Nema rating of Mena 4/4X (indoor use only) Does anyone have any guesses as to what the constraints are that...
1,804
Our system has S7 1516 F CPU. We have doors that have contactless safety doorcontact that is cat 4 ple rated. The sensor provides us with two...
3,001
Was wondering what is everyone using for outdoor rated OIT/Panel View covers? OIT is mounted on a panel. Shade would be preferred as the panel is...
1,201
I need a small HMI or numerical keypad to communicate with a Click PLC to enter a 4 digit number. It'll be mounted outside but under a canopy and...
1,846
