Double acting Valve
qwemx
Jul 2017
Earth
195
I have double acting valve.
this need to be opened and closed .
now Valve remain open as long as power is connected to slenoid on power loss valve closes.
the solenoid is 4 way single coil
http://www.flowlinecontrols.com/solenoids/solenoid-valve-12.aspx
Is it possible to make it function in this manner give power to solenoid for few seconds and valve opens supply to solenoid is turned off and valve remains in OPEN
then next time when power is given to solenoid for few second it changes state open to close. this power also turns off after few seconds
Basically 3 second pulse for ON and 3 second Pulse for off .
In a word NO, You really need a 5 port valve with two solenoids pulse one to turn on pulse solenoid 2 to turn it off, What it actually does is 5 ports pulse solenoid 1 to energize one way & exhaust other port, pulse solenoid 2 to reverse this. (note these are what you call stay put so do not need coil energized all the time). There may be pneumatic logic blocks out there that act as flip flops then you would need a slave valve to do the work.
you can not do what you want with the valve you have it is spring return when power is removed
what you want is a 2 coil valve one coil to open and the other to close
your diagram is a standard cylinder control valve the arrows show the connected ports for the 2 states of the valve
port 1 is the incoming air supply
ports 3 and 5 are exhaust ports
ports 2 and 4 are to cylinder
any supplier should be able to get you what you need
Hi, guys. At first sorry for my english, im not english speaker. Im trying learn ladder and i cant figure out this sequence; i have 2 push...
2,328
Dear, my question is what is the difference between single acting and double acting float switch, is it only the counterweight? or it should have...
2,960
HI EVERYONE I have a double acting cylinder as a diverter.I want to write a program to do the following steps. Parts are droped in left chute and...
7,410
I'm going to connect a double acting solenoid valve to a plc ... In one of the forums I read that the double acting SV does not have an initial...
4,014
Hello, I have a question about getting individual bit information from a double word using Siemens S7. We use Siemens OP panels and the alarm...
13,225
