Doubt aboutn the parameters of a MVM instruction on a SLC 5/03 CLP
giovani
Jun 2003
Rio de Janeiro
18
Hi everyone,
I want to ask you guys if I can use an output digital word (O:6, for instance) as the Dest parameter of a MVM instruction on a SLC 5/03 PLC.
Thanks again for your help.
try
Did you tryed before writen your post?
Put your analog address in the dest and verify the rung. If an error occur, the software will show you.
Giovani...
Yes, the MVM instruction works fine as you asked. I use the MVM for checking inputs as well, eg. when I've got a lot of cylinder positions to check prior to startup. If the mask is dynamic though, you may want to add some checking/inhibiting for the mask value in case of collisions or operator safety.
Steve.
Hello Guys, Hope everyone is doing well. I have a general doubt about ladder programming. The outputs are not getting energized when I used the...
1,882
Hi all, I'm working with FTVS and I'm trying to give a title to a dynamic popup that shows what device it is currently operating. I've seen that...
1,950
Hi all, I'm quite new to the automation world. I've used a bit Tia Portal in the last month and now i have a new working in rslogix 5000. From...
5,070
Hello everyone! I'm currently programming a safety logic on Studio 5000 Logix Designer V33.00.00 and I wanted to know if there's a way to test...
1,591
hi all, I'm working on Studio5000, structured text language. I have several buildings and for one of each several BOOL alarms in an array...
2,025
