Download from Protool using MPI
costimarin
Jan 2005
Hi
I have an OP 3 from Vipa and it has only MPI conection (it doesn't have the standard conection for download that are at OP7, OP17 etc.) . I was trying to download the project but always got the message: "No connection to the OP".
The protocol and the cable I am using are the same like I am using for the download to the PLC:
- PG/PC Interface = PC Adapter (MPI) - I was trying with PC Adapter (Auto) too;
- the cable is the normal MPI cable + PC Adapter.
If someone of you have did this before and it was running please describe me the steps to follow.
Thank you.
From my memory,the OP3 does not accept an automatic download, it has to be told to transfer. To do this you go into the menu for the machine, then into OP mode, to which you select/scroll to MPI download, not just transfer. it should then be possible to download via MPI, also check that you have selected MPI download instead of serial on the project window....... having said that I usually download from the PC adaptor into the CPU out to the OP via the MPI (Profibus) cable..or use the propietary cable for download
siemens RS232 - C79451-A3437-B122 FOR SERIAL DOWNLOAD
CHEERS
RMA,
yep its me !!
Suzuki GSXR K4 600
IOM last year, Manx GP Senior..
Although I also race the national road races ( Public roads ! ) :D
HI I'm trying to download Protool Project to the HMI using seriel cable. But I am getting communication problems. Please can you help me.
2,339
I'm trying to download a Siemens Protool project into a OP17 with USB to RS232 adapter. The download is starting but it interrupts at approx. 80%...
6,652
Hi, I'm trying to download a basic project from protool v6.0 sp2 to a OP17(6AV3 617 1JC00 0AX1 - OP17-PP),The project compiles with no errors and...
10,886
Hello, i've been at this for months now, i tried creating accounts on the aveva website but it seems to never approve my accounts or at least when...
23
Hey guys, I have to take an upload of a program on an S71200 PLC to change a hardware config option and then redownload the program with this...
111
