Downloading a project file to an IDEC HG3G HMI using a USB drive
Epy
Jul 2012
no
376
Hi, trying to use the USB autorun functionality of the HG3G to download a new WindOI-NV2 project file into the HMI.
My project file extension is n3g and I have the option to save as z3g for a project transfer, which is what I want I'm pretty sure. Problem is the USB autorun tool expects a znv file. Is it not possible to do this with an HG3G? Is it only there to download to a connected IDEC PLC?
I contacted support but only got a PDF version of the help file, which doesn't seem to mention z3g files at all. WindOI-NV2 help wasn't much help either.
At this point, guessing it can't be done, or the autorun tool needs to be updated or something. I tried renaming the z3g file to znv extension but got a file format error when I tried to download to the HMI.
Nevermind, got some help on this elsewhere. For anyone who searches, you go to download in WindOI-NV2 as usual but select memory card as what you're communicating with and that will dump the needed znv file onto a thumb drive. Then you can use the USB autorun tool.
Hello everybody, I have a problem with TwinCAT 3. When I try to activate a configuration and start IPC in Run mode I receive an error AdsWarning...
5,671
Good day, may i ask if downloading the project in proface hmi GP3000 series is that simple,in transfer tools using "Send Project"?and when i want...
1,893
Is there something that I can programmatically do to prevent motors from starting when downloading?
4,369
Hello, I have been asked to handle a mission impossible and need help from you all. My previous engineer handed me a Schneider HMI (XBTGT7...
2,115
Hello everybody, I have two add_on in my project. The first add-on calls to the second add-on. There is a parammeter type BOOL[32] in second...
3,238
