Downloading Without RSNetworks Ethernet I/P File
Winklehoffen
Jun 2009
Auckland
46
I have a customer with a plant using a Compactlogix L43 and a stack of Ethernet comms to drives and so forth. They want me to add another drive in and so I need to add that on the network. My concern is that I don't have any of the original files for the plant and have only uploaded the program from the PLC. What will happen if I add my new drive in to the uploaded program then download this into the PLC without the RSNetworks Ethernet file?
There is an SEW Movidrive on the network too so I have some concerns about whether that will still work after my download and I really don't want to have to touch that.
If I go into the ethernet module properties and click on the RSNetworks tab I get file not found. When I click OK it asks me if I want to create the file, so I do. I then get some warnings along the line of:
Warning: Failed to create new chassis in EtherNet/IP project file. Verify EDS file exists: 0001000700440301.eds
And:
Warning: Failed to create new device in EtherNet/IP project file. Verify EDS file exists.
So obviously I don't have all the correct EDS files but can I still download my modified program?
By the way this is a RSLogix 5000 v15.02 program.
Unlike with ControlNet, RSNetworx for EtherNet/IP has never been required for configuration of ControlLogix projects.
Don't worry about the missing .ENT or .EDS files; just validate and download the *.ACD to the controller, and the Ethernet bridge modules will take care of creating the connections to the drives.
Software: RS 5000 v18.02 This is my second time running into UNK instruction. Rung is in e mode, with UNK instruction replacing original MOV...
10,511
Is there anyway of downloading a program to a SLC5/05, without changing the values of the data on the data files. I have tried to use the static...
2,288
id like to know what would be the best and cheapest way to download an application into a PV700 or PV1000 i have an application that have been...
4,048
Hello All, I have a problem which may just be because of lack of familiarity with Allen Bradley. I have an off line project in RSlogix 5000 which...
12,649
I am kind of new to GE products, but we have several in my area. I made a minor logic change and it verified good, but when I tried to download I...
48
