DPI Error - Object State Fault
Jan 2016
UK
85
I have a powerflex755 with safe speed monitor module card. The system while running suddenly shutdown with no apparent cause or alarms. The electricians didn't know any better and they changed out the safe speed module first. Went online to the drive using connected components and tried to change some config on the new option module to make it the same as the old one but we kept getting the error 'object state conflict' (see attached). It was only occurring on some of the parameters and not all.
Local rep said to change out the drive and so we did. We are still getting the same error. So right now we have a new drive, new safe speed option module and the same error with no luck. I am directly connected to the drive using my laptop so no datalinks should be blocking the device, there is no devicelogix in the device, it is a brand new drive and I/O look to have been disabled to the drive. I have googled but this issue does not seem prominent at all.
I am at a loss, please help.
So we swapped out the safe speed monitor board and it worked after just fine. It boggles my mind how the first board was bad out of the factory.
so the 1203-sss is a DPI device, the 1203-USB says it will do DPI/DSI. is the 1203-sss capable of communicating with the devices using DSI like...
1,462
Hello, Once every couple days or so we get a DPI Port 5 alarm on our Drives. This will happen to one drive at a time. We have changed out both...
5,084
Does anyone have a cause/solution for why PF700 drives have intermittent Port 5 DPI Faults (F85), which is the internal connection fault. I have...
10,372
Hello fellows. I just ran into a rather interesting issue. Our plant was down this morning so I was going around uploading all my drive profiles...
4,409
Rockwell refers to their DSI or DPI devices but I can't find in any literature what this acronym stands for. My first hunch was Digital Serial...
10,744
