Mark Snodgrass
Does anyone have a cause/solution for why PF700 drives have intermittent Port 5 DPI Faults (F85), which is the internal connection fault. I have seen some suggestions of a firmware issue causing it, but of my 4 drives I currently have a problem with, they have 3 different revisions (3.002, 4.006, 9.001). They are all using 20-comm-E cards with revision 4.001, could this be the issue? We had another drive at one time that had the same issue with 20-comm-R cards, until we used up all the older cards then the problem went away.
The problem mostly occurs overnight (we only run one shift), but sometimes faults during the day while we are running.
I know this has been an ongoing issue for Allen Bradley in the past, and I would like to find a solution to this problem so I can worry about other things.
Thanx
Mark Snodgrass
Thanx
Mark Snodgrass
