Draw a digram
vetal1sa
Sep 2016
Ohio
A discrete 120 VAC output module is to be used to control a 230 VDC solenoid valve. Need to draw a diagram showing how this could be accomplished using an interposing relay.
Can somebody draw a diagram and add some explanation?
:confused:
I just lost in that but I think it should be something like this.
lp5ga0yeb
You labeled "L2" DC. "L2" is the neutral side of your 120VAC power, it does not need a label.
But if you insist then "N" or neutral will do.
Why the normally closed contact on the neutral side of the interposing relay coil?
That is not necessary. The only place you normally see that is on motor starter contactors where the contacts are controlled by overloads (is that what you were thinking?).
Hello, I want to plot a line on X,Y axis with defined start and end points on Quick Panel+. I use PAC Machine Edition 9.7, and it supports...
1,753
355
I want to draw a shape on a screen page in TIA/WinCC. It's roughly the shape of a canal boat hull -see picture. I couldn't find any "free-form"...
1,572
I was wondering if anyone had any insight on to how i could monitor and possibly graph Amp draw on our Powerflex 525 Drives. These drives are...
1,766
Hello, anyone knows where to find Rockwell/Allen Bradley shapes or stencils for visio (microsoft) or draw (libreoffice)? I am interested in...
7,525
