Dreaded Grey PV+ Screen
Narlin
Mar 2010
phoenix
320
Here is one I haven’t seen before. When I press the standard Acknowledge button on a PV+ Alarm Screen, it is set up to put my alarm number into an integer word for 3000 mSec, which it does nicely. However, it causes the screen to go Grey and become unrecoverable except by power cycle. Or if I am running in emulation mode, then I can recover by killing (X) the emulation and starting up again.
I haven’t been able to find this in the manual. Has anyone seen it or have any idea how I might correct the problem? By and by, it is the same with ACK_ALL.
narlin
Solved!! The alarm screens ON TOP check box had been changed to REPLACE. When it went away after acknowledgement, there was no screen remaining -- thus GREY.
narlin
There's a checkbox in the PV+ setup menu somewhere that says something like "Close display on acknowledge last alarm".
Unckecking it will also solve your issue.
Hey guys. A little sticker shocked the last few months with how much my electric bill has been. Even though it is summer, we haven't been home...
6,415
Not a question...just a post to help out anyone else who might someday waste hours on this same issue. I'm building a data logging application in...
5,402
Might have a need for indirect addressing, could someone please explain this so even I can understand. Using AB-5/40E processor.
2,114
When an alarm (or event) not sure where its pulling from occurs, not only does the alarm list populate but a grey bar along the bottom of the...
1,071
This started to happen more frequently, Suddenly all HMIs screens turn grey. I could not even open the client file on the server as well. When I...
1,576
