Drive for 2 axis movement
dani90
Apr 2012
Canada
39
i'm looking for drive or drives that should"
run vertical and horizontal conveyors,
both should sync,
able to run in different speed,
thanks for your feedback
What sort of loads are you lifting ? Anything safety related or overhead ?
How closely are the drive axes coupled; you refer to them as "conveyors"; is the horizontal axis lifted by the vertical axis ?
How closely do they have to synchronized to one another ?
If a servo and its shaft brake failed, how would your system prevent the load from falling ?
Do the drives have to connect or integrate with a particular type of PLC controller ?
No question about Yaskawa A1000
https://www.yaskawa.com/products/drives/industrial-ac-drives/general-purpose-drives
unless its a hoisting or safety is an issue in the application then go with Magnetek Impulse drive
they are designed for crane hoisting applications
https://www.magnetekmh.com/Products/AC Drives/IMPULSE AC Drives
I have use both for years you will not go wrong with them
Also if I remember correctly from a job up there a while back you will need a VFD rated for 600Vac input that may limit your selection. Both of these are available with the 600V
No
axes are not coupled. horizontal conveyor transfer items to vertical conveyor.
both should be synchronized in certain length.
the motors are attached to gear reducer.
Siemens plc
I work on a couple of machines with in and out transport carts that share a common track.
They are controlled by a 2 axis Parker CompuMotor servo controller going to 2 servo amplifiers, run by an Omrom PLC - but do connect to other PLC's as well. Learning their Motion Planner software wasn't a big learning curve as it is structured text with some special commands.
I have a customer with a Kinetix 350 servo drive. They were having issues with the old servo motor so they replaced the servo motor with a new...
18
8,434
Hello all, I am having a problem that i have been struggling with. I have a kinetix 5700 dual axis drive and one of the axis on the drive remains...
2,817
a Rockwell Kinetix 7000 drive and motor are actually removed from a machine. the project was engineered with RSLogix 5000 using motion axis...
3,440
I'm building a single axis system for a custom grinding operation we have. I'll be using a .200 pitch ball screw direct drive from possibly a Sure...
2,404
Hello all, I am currently trying to program a PowerFlex 525, version 7.0. We had a power outage recently and when the power was restored, the...
324
