Dual Loop PID Controller
Money4Nothing
Apr 2006
Longview, Texas
224
Has anyone ever used a stand-alone Dual Loop PID process/temp controller that is programmable to automatically select between two PID loops to control a single output?
Most of the controllers I find only have manual select between the two control loops.
Yep, done it a couple times with a Honeywell I forgot the model number, maybe cheaper to use a plc?
Edit... it was a UDC6300
I only know you can do this with a Sipart because I had do replace one with a Plc ;-)
If you have to do advanced control with these non-plc controllers, it's either a mess to program them via display, or you also need some kind of programming software.
Hello, Its my first time working a project that involves PLCs. I need to develop a way to track parts with serial numbers that are passing through...
5,284
86
Currently we have a fat( I think that is what it is called) Intouch application. An application resolution of 3840x1080, and inside that 2x...
93
Hi I am being given several fault words (as a DINT) from a Drive that I am receiving into a Compactlogix L33ER controller. I have a small...
1,144
Hi everyone. Ifix scada is new for me. Please help help me to clarify is it possible to open Ifix scada runtime on dual monitor and how to do? Thanks
444
