Hope you can help me,understand my english and problem.
I'm beginner in all this stuff of STEP7.
and I got stuck in a STL network.
I want to use 1 DB as a parameter of another DB.....
I mean:
"dbSend".Txt["dbBuffer".Data[1]]
the Txt is an array of string, and the Data is an Integer.
I need to do this cause I'm using the block AG_SEND (FC5) and I want to make dynamic the parameter Send which specify the address of the data to send.
I have try to move my "dbBuffer".Data[1] to a local variable (Int) and then call it "dbSend".Txt[#Address]!!!!
Thanks in advance for your help!
I mean:
