Dynamic Load Shedding algorithm
Chandrashekhar
Guest
C
Hello,
we are implementing a load shedding program using a PLC based system.We are using S7 314 C2PTP Siemens CPU.
The basic structure is as follows:
The system consists of Four generators of 3 MW capacity each and is operating in synchronisation within themselves.The power generated from the generator is fed to four load centers , each load center consisting of critical and non critical loads.In case of loss of generation or sudden increase in load, load shedding should take place. Could any one help me in giving me an algorithm for dynamically shedding the non critical loads there by not allowing total black out of the power system .
Also we understand from the system integrator that the above mentioned model CPU cannot be used for such fast acting applications and they are suggesting to go in for S7 400 series.Pls help me in providing your valued experience .
regards
Chandrashekhar
Hey All, I've got a Vacon x4 VFD running in open-vector mode. It is spinning a heavy pin-mill wheel. It gets frequency reference from a PID...
20
2,558
Hello, I have a requirement to manage the text alignment dynamically. So, for example: 1. English Texts should be displayed from Left in...
99
Rockwell Tech Support seemed to have hit a wall with this question. Already updated the version to 5.00.13 per their suggestio but am still...
252
Maybe this is just not possible, or maybe I am doing something wrong. Background; I have a data array of over 1500 products. For sorting I...
769
HEllo, still satruggling with the curse WinCC Unified. See attached picture. I just want to change the fill colour from turqoise to grey and then...
495
