E&H Dosibox TI050 Output bit reverse
SHKODRAN
May 2010
Italy
102
Hello to all ,
anyone have experience with this object?
I would like to reverse the function of the outputs (NO, NC), but can not find anything about.The device is connected with S7-300 throught profibus.
Someone has a manual or something that can help me figure out how to do?
Any help is appreciated.
Thanks in advance.
Regards.
Hey all, I am starting a new project for a customer and I am adding in solenoid valves. Once added, I noticed there was a lack of an Output...
70
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
163
Hi, I am using AB 5069-L306ERS2 CPU. My system should achieve SIL-2. I have safety door switches connected to AB 5069-IB8S module, and I want to...
111
Hello! Hope you are great. I need to make a change in a PLC with ladder logic. I will mount a analog valve and I need to control it in ramp up...
320
I have a 170AAO92100 card that I am interested in using as a 10 volt output. Is there setup that I have to do in order to change output or simply...
86
