Easy Replacemnet of HMI's, PLC's and Drives
Mark Wilson
Nov 2013
Franklin, Tennessee
Looking for tips on making replacement of failed PLC's, HMI's and Drives easy for E&I techs. This would be all Rockwell Automation Equipment.
I see that most of the Logix family has the ability to use flash cards to take care of this and I think the HIM will handle all of the Drive Parameters as well as the newer Logix Gear will do an automatic device replacment of drives from what I understand.
Looks as the Panelview Gear (We have standard and Plus)has the ability to use flash cards also.
The one area where I have not found much info is the Allen Bradley computers we have some of the 6181 Panel Computers and 6155 Compact Computers and a few 6177 series Computers in towe and rack mount.
I see these have a clone utilty with them. They have quick removal hard drives so can I remove the hard drive from a failed unit and install it into a new unit? Or is it more involved than that?
Looking for any Tips as this is still all very new to me.
See picture. I want to add a rung (magenta) into the existing code. Can't figure out how to do this. I select a -||- , right? When I drag/drop...
21
1,812
Hi All, On my site, the standard template for storing recipes in the PLC is to create a tag called PartRecipe which is an 2D array - for example...
1,476
I would like to do change a kinetix drive, so i believe i just have to put the IP address in the new kinetix and just connect right? Do I need to...
1,203
Hey all, I am trying to check in logix designer in emulator and I need to check the hmi alarms by toggling bits to activate an alarm . But...
2,072
Good afternoon guys, I have a basic question on the bubble level in the picture attached. This is probably really easy, but I don't get it, haha...
3,378
