Easy way to convert Panelview+ 700 to 1000???
RPax
Feb 2004
125
Hi, just wondering is there any quick way of converting a panelview plus 700 to a panelview plus 1000 application in RSView.
Will I need to create a new project as panelview plus 1000, import the graphics, change the resolution size and start rebuilding alarms\Comms etc.
Appreciate any feedback on this. Thanks - Rpax
Good news... both the 700+ and the 1000+ have 640x480 resolution. You don't have to do anything to your program for it to work on the 1000+...just download.
Thanks HD_Coop, will I need to reset all my comms to point at a panelview + 1000. Thanks again - Rpax
I've got this PV700+ project designed with a lot of momentary push buttons that needs to be maintained push buttons. I'm looking for an easy way...
2,772
See picture. I want to add a rung (magenta) into the existing code. Can't figure out how to do this. I select a -||- , right? When I drag/drop...
21
1,800
Hi All, On my site, the standard template for storing recipes in the PLC is to create a tag called PartRecipe which is an 2D array - for example...
1,474
I would like to do change a kinetix drive, so i believe i just have to put the IP address in the new kinetix and just connect right? Do I need to...
1,201
Hey all, I am trying to check in logix designer in emulator and I need to check the hmi alarms by toggling bits to activate an alarm . But...
2,069
