Easy Way To Tune Pid
I'm not guessing. I put there code into MatLab and adjusted the Kp. Now I maybe doing something wrong since it has been a while.
About the post of beware of the so called experts.
Even in my early days of setting PID loops (before I was taught) I never found it too difficult, usually if it could not be tuned it was a problem with the design of the system not the PID controller (I refer mainly to direct steam injection into product in-line one of the hardest to control).
I have worked on many systems including ovens, speed control, heat exchange in-line injection, I worked with an expert in steam injection who designed a well known system, used extensively in food production controlling in-line cooking to +-0.5 deg C, this system used pressure & temperature control on the steam (one of the hardest to set-up).
Just because some people out there have no idea dosen't mean we are numbskulls.
I am currently working in a food envioment where we have 22 plants producing food using probably more than 50 pid control loops, most of these are using PLC based systems, incidently I have set up all of these, so I think even by default I can be called a sort of "Expert".
The answer
Values of KP
0 < Kp < 5 overdamped.
Kp = 5 critically damped
Kp > 5 underdamped
The key is to find where Kp is critically damped because that happens at just one point. A critically damped system has all the poles on the negative real axis at the same place. The denominator of the transefer function for proportional control is S^2+10*s+(20+Kp) and this must be equal to a form of (s+x)(s+x) where -x is the location of the poles. (s+x)(s+x) = s^2+2*x*s+x^2 and that is equal to s^2+10*s+(20+Kp). I can from the coefficients for the first power of s that 2*x = 10 therefore x= 5 which means there are two poles at -5. Now I examine the coefficient for the 0th power of s and see that x^2 = 20+Kp. Basically I am just finding the roots of the polynomial. Since x = 5 then Kp must be equal to 5 too. The fact there are a lot of 5s is just how the problem worked out.
I can go on but I won't unless someone expresses some interest. I don't think there are many that understand the web page Ron posted a link to. I do think a lot can be learned from examining that web page closely. If I do I will start a new thread.
See picture. I want to add a rung (magenta) into the existing code. Can't figure out how to do this. I select a -||- , right? When I drag/drop...
21
1,801
Hi All, On my site, the standard template for storing recipes in the PLC is to create a tag called PartRecipe which is an 2D array - for example...
1,474
I would like to do change a kinetix drive, so i believe i just have to put the IP address in the new kinetix and just connect right? Do I need to...
1,201
Hey all, I am trying to check in logix designer in emulator and I need to check the hmi alarms by toggling bits to activate an alarm . But...
2,069
Good afternoon guys, I have a basic question on the bubble level in the picture attached. This is probably really easy, but I don't get it, haha...
3,362
