Easy xlogic PLC
joegge
Dec 2013
Bolderslev
Hi everyone.
I think i have problems with noise disturbing the Can BUS on my Xlogic 18-DA-RU low cost PLC. I have random dropouts on the outputs(only ext. units).
Noticed that there is an EOL resistor (120ohms) in all extension units on the outgoing com socket? i am thinking about disconnecting them except the last one, after eleminating programming bugs, faulty adressing, peaks on inputs, shielding bus cable, cheked power supply etc.
Any experience with can bus problems or Xlogic PLCs anyone ?
See picture. I want to add a rung (magenta) into the existing code. Can't figure out how to do this. I select a -||- , right? When I drag/drop...
21
1,830
Hi All, On my site, the standard template for storing recipes in the PLC is to create a tag called PartRecipe which is an 2D array - for example...
1,482
I would like to do change a kinetix drive, so i believe i just have to put the IP address in the new kinetix and just connect right? Do I need to...
1,206
Hey all, I am trying to check in logix designer in emulator and I need to check the hmi alarms by toggling bits to activate an alarm . But...
2,074
Good afternoon guys, I have a basic question on the bubble level in the picture attached. This is probably really easy, but I don't get it, haha...
3,386
