EB8000/451 and "Station No" question
CalG
Feb 2013
VT
197
I would like to connect directly via Com ports (RS 232 or 485) and control two GE 90/30 311 PLC's.
The Easy Builder software "speaks" of "Station numbers" in Chapter five "How to Control a Local PLC", but the wording is rather obscure to someone who is not familiar (me ;-)
What is the best way to set up both the 90/30's and the Weintek 8070 hmi for the most reliable communication?
Are there advantages to connect one plc via 485 and the second 232 with separate cables? Or is the 485 multi drop a better choice? (custom cable required)
I have the Horner communication modules available for both plcs so there are port options. TCPIP is NOT available to the PLC's. The HMI is configured for network communication and that works well.
What I am missing is the plc I.D and how to address commands from the HMI.
What are valid plc ID's?
and how are references directed correctly in the 8070 HMI?
%R00001#(plc ID) ?
TIA
Cal
I need a multi state indicator to display based on a register value. I can create it and it works fine my problem is the only one with the most...
1,404
I am new to Easy Builder 8000 although I have managed to write a few screens and put them into use (a lot cheaper than PV+) Can anyone tell me how...
1,536
I found a post asking about RS500 and EB8000 in online simulate and am trying to do the same thing.The post said to shut down RS Linx so it would...
2,289
I have used the Numeric display once before on a MT8070iH and used a 16 bit unsigned integer N7 then added the decimal point in the Numeric Object...
1,901
I downloaded EB8000 for a Weinview Display MT8070iH5, I can successfully download the application but can not get it to communicate with the PLC I...
18
5,027
