EDS and device net download all EDS files at once?
jasil
Jun 2012
Building
48
New computer......how can I download the 200 different EDS files I have at one time versus registering each device individually....which would take forever.
Rs networx 11
RSNetworx 11 stores the EDS files all in the RSCommon/EDS directory, but also registers them with Windows.
The best way to migrate all your EDS files from one computer to another is to:
1. Copy the contents of the C:\Program Files\Rockwell Software\RSCommon\EDS directory on the old computer to another temporary directory on the new computer.
DO NOT put these files directly into the RSCommon/EDS folder on the new computer !
2. Run the RSLinx EDS Hardware Installation Tool (Start-> Programs-> Rockwell Software->RSLinx Classic->Tools).
3. When you do the "Add" function, you can select to register a whole Directory of EDS files. Point the utility to the storage folder where you've put the EDS files.
I cannot emphasize enough that you absolutely DO NOT want to manually put files into the RSCommon/EDS directory.
I'm told that RSLinx Classic 3.x changed the way EDS files are stored and registered, and I'm unfamiliar with those details. Because you're using RSNetworx 11, you're probably using RSLinx Classic 2.5x and these directions are appropriate.
Hello. Have been struggling the best part of today with this one issue that I try to explain with the screenshot below. As I show from the EDS...
3,302
Hi Folks I am getting a bunch of warnings and not letting my project to build up in a VM and running a simulation. Warning: Potential issue...
4,721
Hi, guys I am trying to add some devices to my RSLogix 20.0 project. When I register the files there is no errors but when I try to add the...
3,541
Question – I am running the RSLinx Classic Gateway OPC server (4.00.01 CPR 9 SR 10.0) on my laptop, with a directly connected Ethernet/IP...
2,627
Hello all Can I remove a device in RSLogix 5000 from the hardware where the EDS file is missing? How? Thanks!
2,963
