EDS file for PowerFlex Drive?
busarider29
Aug 2013
Midland, MI
399
Greetings from Michigan,
I want to use a PowerFlex 755 drive with a Beckhoff controller. The drive has a "PowerFlex 20-750-ENETR Dual-port Ethernet/IP module" on it. I plan to use that and communicate with it over ENet-IP. What EDS file/s do I require and is there one available, either for the drive, the module, or both? I found EDS file for PowerFlex 755 drive on the Rockwell website, but the link to download it says "PowerFlex 755 drive with Embedded Ethernet IP". The drive I am using obviously does not have Ethernet IP embedded.
Thanks,
D
If you got to Rockwell PCDC website search just “powerflex 755”. It will show you the 755 profile along with the other 700 series drives. Click on “select files” the eds files download is at the bottom of all the files listed.
The PF755 has embedded ethernet, it can also have the 20-750-ENETR.
The PF753 does not have embedded ethernet for that you will need an add on module, it could be a 20-COMM-E with adaptor or the 20-750-ENETR.
The 20-750-ENETR gives you the choice of using DLR (Device Level Ring) on the PF755, you can control the drive by the card or use the 300mm supplied cable to connect to the embedded ethernet port.
The 20-750-ENETR has a switch on it the lets it act like a 1783-ETAP or to act as normal ethernet card.
Alan
Hi, I got the ESD file for a PowerFlex 70 from the Allen Bradley web page. But, when I want to add it to the RSNetworx a message pops up and tell...
5,404
2,918
G
Hi folks... I got the ESD file for a PowerFlex 70 from the Allen Bradley web page. But, when I want to add it to the RSNetworx a message pops up...
6,964
Guest
G
Hey y'all!! I'm looking for an old EDS file, GSE 560. I can't find them anywhere. It is for a GSE560 display on a DeviceNet network, with...
76
Hello, This product that I have the 1790D-T8BV8B is discontinued, does anyone have the EDS file for it? I wonder if TechConnect will have this...
188
