Ei202 servo Control Techniques
jimtech67
Jun 2002
New Jersey
505
I have a Emerson Motion Controller
Control Techniques Ei202 servo drive Indexing
With motor NTE-207-CONS Brushless servo motor
Issue 1
Every so often the drive powers loses its application program.
Using Power Tool FM v4.2 I download the application and
then operation is normal.
Issue2
Every so often I get fault u (Low DC Bus)
The fault will not reset
after a period of time. (Drive is powered during this time)
The fault can be reset ..
The drive is powered with 120VAC single phase.
During the fault period I measure the following
118 VAC acrross LI and L2
156 VDC across the BUS (+ -)
The customer said they have power issues but could no elaborate any further.
Any suggestions or has anyone else experienced this ????
Hi, I'm working on Mitsubishi MR-J5-70A amplifier, and need some advice on selecting fuse size. Main power is 1ph 240VAC, and in the manual, it...
68
Good morning, We've had an issue with a couple of servo valves and was wondering if anyone had seen anything similar. After a drop in pressure...
97
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
92
Hi all, I am having a machine with old 802d sl siemens controller. I am trying to tune servo by Siemens starter software. Anyone experienced...
69
Hi, I'm thinking about using commands for Melservo J5 controller via HMI without PLC. Have you guys done this kind of control configuration for...
139
