Eithernet
mrm37
Oct 2004
23
I am using all AB devices. I have a DH+ network on paper that I am supposed to be installing in the plants. I am starting to play with eithernet and am wondering which is better to use as the network?
mrm37 said:
Simply, is it better to stick with DH+ or go eithernet?
Do you have an installed network of either one?
Do you currently use processors/adapters capable of communicating over either of the networks?
What processor types are you planning on communicating with?
What are you planning on doing with this network (programming/messaging/scada???)
How much traffic do you expect on the network?
There are a lot of factors that will determine the "best" solution.
Ethernet is better, but it depends on the following.
How many plc's in project, if only a few & they are DH+ then use this, if you have a choice go for ethernet as this can sit on any standard factory wide network if there is one, also a lot faster.
only advantage of DH+ is in small networks low cost, easy to setup
Disadvantages only 64 nodes, slow compared to ethernet.
If you are using Controllogix , I would say go with ethernet,especially you want to have network I/O in your project.
we are doing more and more projects using ethernet I/O in the States now and the customers just like it. One benefit of ethernet : you can debug your machine through high speed internet using VPN.
If you are using SLC series, stay with DH+.
All our new installations use Ethernet. We have done several conversions from SLC 5/04s (DH+) to SLC 5/05 (Ethernet) from existing plants, often in conjunction with the installation of a SCADA. As was said earlier in the thread, clients love it because it's easy, cheap, robust and makes upwards system integration significantly easier. Plus, the bandwidth available means the network can be expected to last several generations of PLC if necessary!
I have RSLogix5000 (ver 20) install on my laptop (windows 7) Just installed Wonderware latest version for the first time. Now my Eithernet...
2,840
I have a contrologix 5000 based BMS that has the ethernet card in remote rack 2 slot 7. I can not establish communications to the plc via...
1,501
Hello, We have several Panel View 600's and SLC 5/05 connected on an EitherNet network, through eithernet switches, talking to each other. The...
2,609
What is the wiring color order for RJ-45 eithernet plugs? I am installing a small eithernet network and the crimpers and jacks came without any...
1,960
