Elau Ground/Short Circuit issue.
bigsteve777
Dec 2013
The Land Of Chocolate
25
HI guys anyone with any Elau experience? I have an issue with a grounding/short circuit fault that keeps coming up via the PacDrive Diagnostic software. It's a 10 amp MC-4 drive with a Max-4 controller. The drive faults out and needs to be reset. We have changed out the motor, cables and drive and still have this issue. Does anyone have any further suggestion one what I can look at to try and find whats causing this issue? What are the possibilities it could be the main controller Max-4?
Thanks in advance.
Steve
Has the system been running ok prior to this?
When the fault is reset, does it return immediately ?
Check your PD diagnostics for additional faults leading up to the main one you are having, sometimes the issue can be triggered by something else but land on the last fault.
This issues has been on and off form months and PD diagnostics shows no other unusual faults. An Elau tech we had at our plant suggested that the drive which is older FW Version 11 felt maybe the drive being older could have a bad component. I have since flashed a newer drive town to FW 11. In the meantime they re-terminated all connections again and it has been fine for 3 days. I'll keep my fingers crossed. Thanks for the help!
I am using Schneider elau pack drive servo motor ISH-100. I am facing the problem that On the ISH -100 red light is blinking and pack drive C-600...
83
hi everybody. i try conect whit max-4 and PacDrive Diagnostics 2.1 but i can´t do. i follow ok steps as next link video but in second 0.41 is my...
1,671
Hello, I'm looking to setup a test rig in the workshop for testing the likes of the following units; Elau MC-4 Servo Drives & Pac Drives...
1,780
hello everyone I need Firmware version V00_22_05 for my MC-4 kan anybody help me, i can't found this file Thanks ans regards
5,145
Some of ELAU SM servo motors utilize SICK STEGMANN encoders of type SRM50. My SM motor had a defective SRM50 and I bought a new one from SICK. I...
2,181
