Electricians: Why did I see sparks when using my voltmeter?
khelza
Sep 2015
Ontario
67
Two separate incidents:
-testing lines when replacing light fixture. Hot (120VAC) and N are insulated separately but connected together. Black lead to GND screw (which turns out wasn't actually grounded) and Red lead to Hot.. I'm guessing it's just arcing from touching a live wire with no return.
-testing an output on a PLC where everything has been running fine. Red lead to output, Black lead to 24VDC and then to DCCOM just to see both.. I saw sparks and just stopped testing it.
I'm more concerned about what happened the second time.. but it concerns me when I see sparks when my meter is set to V, and leads are in the proper V and COM ports.
Without more information I'd say bad meter, I never seen sparks on a multimeter before unless you were set to amps and connected across the lines and blew your fuse.
It's your lifeline, don't cheap out on a meter.
As above bad meter or was set to amps.
If its sparking it means there a fair amount of current passing though.
I carried a Simpson 260 for three years. God what a beast. You can't kill it unless the batteries die.
But....I really love my Fluke.
Ok, I was pretty sure that wasn't supposed to happen :eek:.. and yes, I have a cheapie.
Time to upgrade... I'm thinking a Fluke Clamp Meter o_O
Might I suggest the Fluke 336 very accurate, fairly inexpensive, AC/DC, volts, ohms, amps.
Carried this one for five years, never had a problem.
My apologies. Its been discontinued,
Try this
Fluke 375 True-RMS 600A AC/DC Clamp Meter
That's terrifying. Throwing that junk in the trash is sound advice.
Can't help but wonder why you didn't blow any fuses in the circuits you were testing o_O
We have a segmented maintenance staff at a plant and I was wondering when did electricians and /or technicians get the sole responsibility to...
5,118
All, General Motors Corporation utilizes an PLC assessment for individuals applying for Journeyman Electrician positions. They utilize a 3rd...
2,823
When you build a panel, do you megger the wires after you run them but prior to connecting them? What standard do you use to determine whether...
2,102
I'm creating a mobile app that would make it easier for electricians, technicians, and other tradesmen to get jobs. If you'd like to help by...
1,641
Life can sometimes be horrible for normal installation electricians. Bosses just don't seem to know the difference between an electricain that...
2,771
