Emerson / Bristol ControlWave - unknown Password / User ?
slick_william
Apr 2020
Oregon
39
Hi all,
I have a job next week where I will be going online with a few ControlWave PLC's at a customer's site, and we do not know what the usernames or passwords for these PLC's are. The ones I have worked with have always used the default (user = SYSTEM, pass = 666666), but it is possible that the previous integrator used a custom user/pass combination.
My question is, if I arrive on site and I am unable to get online with the PLC due to not knowing the username or password, then what options would I have at that point? I could contact Emerson directly to see if there is a workaround, but I am worried that I will get on site and not be able to do anything due to not having the username or password.
Would anyone be able to offer any insight / experience in this area? I have not worked with many PLC's which require user/pass, so I slipped up on this one during my company's meetings. Wish I had caught it sooner.
The only one I have seen non-default is one 6 to match the older Bristols. I doubt there is a workaround but if someone did change it... well they suck. You can default it and start over I'm betting but I'm also betting you don't want to do that lol.
Yeouch... well thank you for your wisdom. Hopefully they either left it default or can get it from the previous integrator.
Does anyone know if it is possible to create a help file that would, when a user presses F1, bring up a custom help (that I made) about my...
61
Two questions for GE/Emerson e.g. PACSystemsRX3i (CPE330): 1. Is it possible to use 2D arrays inside a function as a local member? (I can only...
67
gents, I am trying to configure communication with EMERSON PK300 controller through port A1 using generic ethernet communication module . I could...
123
Hi there, I'm doing some extensive testing and commissioning with a slew of new Emerson PACSystems RX3i PLCs. It would be convenient to...
126
Hi there, Trying to get some ascii serial communications working via RS485 (COMMREQ functions). I have attached our wiring for the COM2...
994
