Emerson GE RX3I Winloader - Firmware Module Update Failure
ZestyMozzarella
Jun 2019
Massachusetts
79
Spoke to a few outlets including Emerson and some distributors. Apparently updating firmware on subsequent modules past the CPU still uses winloader which I have used before on older 90-30 models.
Trying to update firmware on a IC694APU300A and it doesn't seem to work.
IC694APU300A (updating it’s firmware w/ winloader)
It’s just the first one in line to have firmware updated. It’s on main rack slot 5. Here’s my USB port:
Here’s my serial tester saying it’s good in practice:
Here’s winloader loaded green and set up:
Even if the update baud is higher…it fails no matter what. Tried different baud rates downloading to CPU and setting port settings…nothing.
Just keeps trying and trying…nothing…a wall :(
I'm using the correct CBL316 cable attached to a MOXA USB adapter. Anyone have any idea what the malfunction may be besides the user! heh...
Have you been able to connect to the serial port using Machine Edition?
The serial port should automatically switch from RTU slave to SNP slave when Winloader tries to connect, but have you tried configuring the port for SNP slave? Have you also tried changing the interface from 4-wire to 2-wire?
Hi there, I'm doing some extensive testing and commissioning with a slew of new Emerson PACSystems RX3i PLCs. It would be convenient to...
104
Hi there, Trying to get some ascii serial communications working via RS485 (COMMREQ functions). I have attached our wiring for the COM2...
975
Hello all, First time poster, long time viewer of these forums. Could not find my solution on here. We have had issues with a Comm Fail on an...
383
Hello everyone, I need your help. At one of my company instalations we have GE90-70, and we're going to replace it with some newer PLC. I prefer...
515
Hi, I have a machine running with a GE RX3i system (including a few remote RSTi Profinet nodes). This control system installation is now 10 years...
1,661
